Is there any way to login first in tweak before it’s loading
Hello there! I am using a certain tweak. Whenever I enter into the tweak, it is started to load everything and the login screen comes after loading everything. Is there any way to login first before it is loading?
Do you have any idea how could I do it and it is possible for me to use it with Windows XP?
Would appreciate your reply.
