Hi expert,
Again I am in problem and come to you for its solution. I want to know a very simple thing – is there any way of scrolling image with mouse? If yes, please tell me in detail as I can do it easily. One thing should not be unmentioned – I am a beginner.
Thanks
Is there any way of scrolling image with mouse?
Hello
You can scroll an image with different ways ,you can choose from these ways :
1 – The most common way is the mouse's wheel ,move it up and down to make the image as size as you want .
2 – You can change options of mouse from (control panel ) to make this wheel be any mouse button .
3 – You can also use the keyboard to scroll the image by using this shortcut (ctrl+(plus sign)) to make it large and (ctrl -(subtraction sign)) .
4 – You can also use the arrow buttons to choose between images .
I hope these will help you solving your problem .
