Is there any way to use Wii to access media server?
You can use your Wii device to access the internet. Just click the Wii options icon on your Wii Menu and then select the Wii Settings. Click the Connection Settings and then select Connection 1 if you have not yet set up any connection. Choose Connection 2 or 3 if you have other connection. If you have a wireless or wired connection, you can connect your Wii to any of it. If you will connect wirelessly, choose the Wireless Connection and then search for your access point. If you will connect via wire, ensure that you have connected your network cable correctly to your Wii and LAN adapter.
Click the Search for an Access Point to set up the wireless connection. You will see all the available connections. Choose your connection. Enter the password of your router and then click OK to save your settings. You can now start using your Internet connection.
