Is there any way, which I can bounce email back to sender?
When I receive spam emails I need that those emails to bounce email back to sender itself and notify them that I didn’t receive the email.
To do so you can use the Bouncy bully.
Step 1: Download Bouncy Bully from the following link. http://www.bouncebully.com/
Step 2: Install it on your PC. Make sure that you have Outlook installed on your PC.
Step 3: When you need to send back the email to their senders open the app that was installed.
Step 4: Click on the “Check Email” button and select the emails that need to be bounced back.
Step 5: Click on the “Wash Mail” button and all the emails that were selected will be redirected back to their senders.
