Alex007
20 points
Posted on - 08/12/2011
Recently I have installed the Simple Image Gallery by Joomlaworks. I follow all the instruction carefully. But I am getting same error as follows:
"Parse error: syntax error, unexpected T_STRING, expecting T_OLD_FUNCTION or T_FUNCTION or T_VAR or '}' in /home/blah/public_html/public_html/plugins/content/jw_simpleImageGallery.php on line 36."
I have a little knowledge about this. So, I do not understand what to do. Please help me so that I can fix this problem.
Is there anybody- well known about Simple Image Gallery (Joomlaworkers)?
Whenever you see this error message  on your screen during installation of Simple Image Gallery by Joomlaworkers, simply it means that some file has been corrupted due to any reason or this file is incomplete. This file may also be poorly coded or skipping a closing PHP entity. Try to unzip the files for the extensions locally and then upload these files over the top of the online files. In this way you can solve this issue.
Hi Alex,
Please check your permissions first. Clear your cache and try again. If there are any bad images then remove those bad images. If the problem is due to bad images then you need to check for that as well. Once bad images are removed problem might get solved. Please check following some sites to educate yourself-
Joomla Documentation Basics Beginner's Guide
http://www.siteground.com/tutorials/joomla/
Please refer to the following image for more clarification.
Hope these solutions will work for you.
Thanks and Regards,
