Which is better to use? XP or Vista?
Is there anyone experienced using the window vista here? I want to try window vista but first to know if it is nicely to use than Windows XP. Please share your experience to me.
I’ll just say that the window vista compatibility difficulties with many games while the programs of utility it works in window XP. I don’t experience using vista but I have some reviews and that’s it. And I am using window XP tested for a long time.
In my experience Vista performs better than XP when it comes to files copying. And it also tested by CRN canter for 1.25 GB documents copied. A Vista had a several thing for upgrading such as new feature, improved security and better overall user experience.
Really! So I better try to use a window vista. Because lately I bought laptop and somebody is aware with Vista Window.
Yes and obviously XP is an old hardware so better to use a new one windows vista for your computer running better and more features and premium built in.
Thank you very much for your apprehension about this. I will try to install window vista later and hoping that it will better to use than the others.
I hope you try also the Windows XP, has a good lead over both of the operating systems. It is tested by many users for searching, downloading and even online jobs using these windows. I also have used it about the years.
