Louis Louis
10 points
Posted on - 05/25/2012
Is there anyone familiar with Meghdoot accounts software? I am having a problem here with this software.
I don’t understand what type of error it is talking about? I found no solution yet.
Could someone provide me the solution?
I am attaching the error screen shot below-
Meghdoot Account MIS client
Unable to Continue due to following Error:
Accounts MIS Error in communication. The underlying connection was closed: Could not establish a trust relationship for the SSL/TLS secure channel.
Please check Log file to see whether there are any other specific errors
Actually, there is a requirement of viewing MIS reports derived out of Meghdoot data, in respect of all H.Os and S.Os. This are classified under the permanent Account Heads created on installation of Sub Accounts software. Meghdoot's main task is installed in all the Head Post Offices and post offices identified under Project Arrow.
When you can see the error like Accounts MIS Error in communication, probably the problem took place upon your installation process. Or may be you are using a incomplete script versions of the application. So thus the problem occur. So at first uninstall the previous one, and try to follow the process discussed on the following site- http://sapost.blogspot.in/2010/11/about-accountmis.html
Here you can find out a proper installation process and everything. Highly hoped that, you will be get resolved then.
