Converting PDF to .doc file
I want free converter from PDF to Microsoft word 2000 or 2003 or 2007 please and program or site can give me keywords in easy and quickly way and thanks for your interest of reading my question and answering it.
Hi Mari,
If you are looking for a software that can convert PDF file to Word file, there are various software available for download. But you can only try those software's for period of time. You will need to purchase it to continue using it. The following URLs can help you with your problem:
http://www.convertpdftoword.net/
I hope everything works well.
Thank You.
Hi Mari Tony,
There are many ways to convert a PDF file to word file.
PDF files are uneditable so one needs to convert them to some other format like doc, docx , txt etc. which run in MS Word or Notepad.
These are some steps in image form:
3. If you are not connected to internet, then the easiest of methods to convert PDF files is to copy the data in the PDF file and just paste it in a new word(.doc)file.
Hope you got something useful.
