Is there anyway to convert a outlook pst to lotus notes
Hi All,
I need to see all mails in PST to lotus notes adaptable format.
Thanks
Meows
Hi All,
Thanks
Meows
HI,
Yes there is you just need to download the right converter for converting PST to NSF.
Try this link they have a free demo on PST to NSF converter.
http://www.convertpsttonsf.com/
i hope it help.
One may require Sys Instruments Outlook to Notes software to change pst files to lotus notes, one can with no trouble change Outlook PST Lotus Notes.
This is vigorous, powerful and dominant instrument for one requires changing pst to Lotus Notes.
Using this instrument, one can take it easy and be secure that one will not be unable to find out owner very important emails and other vital mailbox fundamentals. By means of this instrument, one can also move folders from Outlook to Lotus Notes.
Furthermore, due to the software worldwide compatibility, one can change Outlook 2003 to Notes 8.5 or any other versions of Outlook and Notes.
Here is a link to get the software that will change ones pst files to lotus note.
Notifications
