Is there an app for Voice effect android inline call?
I'm looking for voice effect Android inline call app for S2 Ice Cream Sandwich? Trying to find a male to female voice effect changer app. The Inline function must support GNU C.
Hi there,
Thanks for the question. You can do anything with your Android. Unfortunately, I'm not an Android user. I don't know how that stuff works in Android. But to answer your question sir. I will give you a link which can help you further understand about the application you were looking for.
Or you can just simply follow this instruction to change your voice when calling. (It only works in WiFi. Not through your service provider)
1. Be sure your phone is on its home screen. Tap the "setting"
2. Tap "Wireless and internet"
3. Touch the app to launch. Press the dial pad to enter the number you are calling.
4. Press "call".
I tried it on my friend's phone.
Hope it works also in yours.
Thank you.
Spoof App the software get you transform your male voice to female and vice versa. It is a free application but you can use it afterwards by paying. It is a working application and changes the voice pitch. This software also known as phone gangster and can be downloaded through Google play for your Android the smart phone.
Randle Steve
Notifications
