I use my home PC many days but recently I have bought a Galaxy Tab. For the different work purpose I need to connect my Tab to my PC but I try to connect it to my PC it not work. Is there any thought extra I need to connect my Tab to my PC?
There are any ways to connect Galaxy Tab to home PC?
quazi
This is a common problem for galaxy tab users. Yes, it is possible to connect your galaxy tab with your PC. You can connect by using Kies— Import/Sync video to Galaxy Tab with Kies.
Samsung Kies is a software application used to communicate between the latest Samsung devices. It can be used for data backup, data transfer (between PC and Samsung devices), multimedia management, purchase features and device firmware upgrade. This is the address for Kies.
The five simple steps you are going to take is given in the following website.
Step 1: First, Install Kies on your home PC.
Step 2: After installing Setup your Galaxy Tab for Kies connection.
Step 3: Connect your home PC to Galaxy Tab with USB cable.
Step 4: Import your file from home PC.
Step 5: Finally, remove the Galaxy Tab.
There are also some tips given on that website which you can use.Â
Best of luck.
