There are no sound in my computer
There are many causes for this problem. Such as sound card problem, speaker hardware problem, speaker connection problem, speaker power, speaker volume, sound card volume, etc.
First make sure that the speaker and sound card work properly. Then check the speaker power supply and the volume of speaker and sound card turned on.
Make sure that the sounds and audio driver is installed. Open control panel then go to sounds and multimedia properties then click ‘’audio’’. Click advance—‘’sound playback ‘’—‘’Desktop stereo speakers’’—then click—‘’Apply’’. If you do this correctly I wish you can solve your problem. Thank you for your question.
If you have already tried to put other sound device such as head phone or speaker and still there are still no sounds. Try to check your device manager. Just simply follow the instruction:
1. Go to Control Panel > System > then find the device manager.
2. Look if there are yellow question marks especially in the sound part. Because this is where your problem is. If there is a yellow question mark, it could be that the driver is gone/outdated and needs to be repair. You can try and look for drivers in the internet suitable to yours or to make sure buy a new one.
Also please check the jack if your device is inserted properly.
