There are no Transactions Why ???
Hi all ,
In printing purchase orders it use ME9F but in my case it won’t generate any transactions. I checked the output device and it was been configured as LOCL through SPRO. Can you please help me? Thanks !
Hi all ,
Hello Kyler,
When printing, can you ensure that you sending the job to the right printer. Because if you are trying to send the job a printer that is not connected to the network that you are on right now then you will not be able to print.
Check among the printers that are in the printer properties dialog box and select the right one before you send your job to the printer. If is not among the listed printers, then search it on the network and make it the default printer so that anytime you want to print, the printer will be automatically selected.
__
Regards
Lee Hung
