Does anyone here know where I can get an automatic mileage calculator for Android Ice Cream Sandwich version 2.2? Does it also have high-res satellite image map so it's visually and technically easy to use?
Is there an automatic mileage calculator app for Android?
Hello there Jonathan,
Yes there are several apps for you available on Google Play store.
One of them is Gas Mileage Calculator which is free to use.
All you need to do is download it from here, install it and there you go.
Make sure you give the app some rating after trying it.
Hope this solves your problem.
Waall Mike
Hello
There are many applications available for mileage calculation.
One of the best application is Distance Calculator which is freely available at this link:
The features of this application are
1. Calculate the distance while you are walking, biking and driving.
2. Calculate average speed, Current speed and total time while calculating distance. And there are many more features of this app
Hope you got some need full from above post.
Regards
Hock Clotildec.
There are several mileage calculators for Android. You can find them in different website. I include a website below.
You can find several similar types of apps there.
They have pretty decent resolution satellite image.
Hope you like it.
Link FUEL MILEAGE CALCULATOR ANDROID APPS
Link mileage calculator
