Is There an Available Dell Screen Driver Free Download?
Hello TechyV!
Can anyone please help me find any available Dell Screen driver free download? I have a Dell P170s Monitor and I am using Windows 7. Do you think there is an available driver for this? If so, please help me get the driver. If not, can you suggest anything that I can do to make this work? Any advice will be much appreciated.
Answered By 0 points N/A #140917
To get the drivers for monitor which is compatible for Windows 7,
You can click on the links below:
http://www.dell.com/support/home/us/en/19/products/?app=drivers
http://www.driversforfree.com/dt_dm_ded/monitor/dell/dell-p170s-digital/drivers.aspx
http://drivers.downloadatoz.com/vendor_dell/dell-p170s-digital/cat_monitor.html
After you have downloaded the drivers, follow steps below for the
installation process;
– First make sure, that previous drivers are already uninstalled,
– After which,do a restart on  your computer after uninstalling
– When computer is on, it will detect that there are new drivers in the system
  and it will lead you to a setup wizard for the installation of drivers to be   complete
– You can also install drivers manually by going to My computer,right click on it
  and click on properties
– Under properties tab,look for device manager
– On the device manager screen, look for the device that you need to   Install,normally it shows an
  exclamation mark on it which indicates that there  are no drivers installed
– Right click on the device and select Update Drivers, this will lead to a screen
  doing step by step process for installing drivers which also provide instruction
  on what to click or not to click
– After the process, it's best advice to restart the computer for the drivers to   take effect and function properly.
thanks.
Answered By 590495 points N/A #316609
A monitor display whether an analog monitor or an LED screen doesn’t actually require a driver to work. It will work with or without a driver unlike with video cards, sound cards, and others.
Some monitors have drivers like with AOC LED monitor but the driver is actually just for making adjustments on the brightness, contrast, picture quality, and others which is already available when you install the video card driver. With your Dell P170s monitor, there is no driver available from the Dell website.
If you have Dell OptiPlex 780, you can download the complete set of drivers from the Dell website: Support for OptiPlex 780. Select your correct operating system then download and install all available drivers for your computer.
