evelyndnell
10 points
Posted on - 02/27/2013
Hello, just want to ask real quick here.
I want to download a bootable flash drive mini tool that just do basic boot.
Nothing else. Easiest and simplest application I am looking for, for a quick diagnosis on the many computer systems I am handling.
Replies are much appreciated.
Is there a bootable flash drive mini tool available ?
Hello Evelyndnell,
If you are looking for bootable flash drive mini tool for the basic formatting purpose then here are some simple steps that will do your job.
Just follow them step by step:
1. Download bootable flash drive mini tool from this link.
2. Now open the downloaded file, you will see an interface, click on Build Boot Flash Drive
3. Select your flash device.
4. Click on the Next button and wait for the wizard to complete the task.
This will do your job.
Thanks
If you want your Flash drive to be bootable by using the application try using “Rufus”.
Rufus is a small tool that will help you in formatting and making a bootable Flash Drive, such as USB keys or Pen drive, memory sticks and etc.
To download Rufus, just follow this link
Hope it helps.
Search on internet about Novicorp WinToFlash
This software will make your Pendrive bootable.
