Halton Roy
50 points
Posted on - 10/27/2012
Hello experts,
Is there a built in Nokia n800 video converter mac? Me and my classmates are using a laptop with mac operating system, there are some videos from my Nokia n800 mobile phone that needs to be converted to any file format. Mp4 to avi is required for our project; give me some idea on how to get this done using mac operating system.
Is there a built in Nokia n800 video converter Mac?
I will help you to convert the video files on Mac. You need QuickTime Pro and WMV Player for Mac. Install both the apps. Then open the video file in QuickTime. From File menu, click Export. In the export window, choose output as .avi. It will ask you for export settings. Change the resolution and other required things there and save it as avi. Your video is now converted.
