Hi guys,
Is there a cc cleaner for android tablet? My brother’s android tablet was not yet scanned for many days and I’m afraid of getting some viruses from my internet download. I would like to check and scan it using some cc cleaner software.
Expecting some help, thank you.
Hello Brenda.
Did you mean CCleaner(crap cleaner)? If you meant the CCleaner, then surely you can have this. Actually, this is one of the best maintenance software for tablets and android phones. This will protect your device and remove any unwanted and temporary files.
You can download this from https://thetechjournal.com/electronics/computer/software/windows/download-ccleaner-3-06.xhtml. After downloading, you will get instructions on how to install this. Hope you can remove the unwanted files now.
Thank you for your question.
Hi.
At this time there is non CCleaner Android app, but there is one in development. Unfortunately the release date is unknown. On Google play service you can find some similar application. One of theme is Clean master. Clean master is all in one solution for Android devices. It cleans all unused files, files, remained files and search history. Also it can show how many RAM is used on your device and what is slowing it down. Clean master app is free.
Queen Norman
