Is there a chrome app for recording video?
Hello, I would like to ask if there is an existing chrome app for recording video? I only know for audio but I'm not so sure about videos. Hope you can help me. thanks!
There are not much video recording extensions for Google Chrome. Here is one https://www.nimbb.com/Tools/GoogleChrome/ , but that is just a trial version. You have to buy it if you want it for long term use.
You may also want to try using the following:
https://www.dvdvideosoft.com/products/dvd/Free-Screen-Video-Recorder.htm
http://www.nchsoftware.com/capture/index.html
These video recording softwares are not extensions of Google, but they are free and works really well.
Hope this helps. Good luck!
It’s difficult to find out chrome application which allows you to download video from online. Basically there are not much video recording extensions.
The best way to recording a streaming video is download some software. IDM can help you to download streaming video while it’s playing. After you install IDM, it will capture automatically the streaming video url and ask for your permission to download.
It’s the easiest way. Otherwise, you can go with
http://ww1.screenrecord.net/?subid1=13604706-f475-11e7-8b68-25db080017fd
It allows you to record streaming video too.
Notifications
