I need some converting mp3 to asf software, because it is very important to keep my filers in asf format, so if someone knows what should i do, which converter to use, or you can tell me how to manually change the format, if it is possible at all?
Is there converting mp3 to asf software?
It is not possible to change the format of mp3 file to asf. Although you can play .asf files in other media players through advanced codecs, you have to use software to convert mp3 into .asf format. There are many converters available on internet for you to download in order to do the conversion. You can do a Google search on the keyword "mp3 to asf converter free download", and choose a better converter from the list. But I should say you that most of those softwares doesn't work well. But I use the media converter called "audio video to WMA converter", and I think it would work for you as well. This is how you should download it.
* Do a Google search on the keyword "audio video to WMA converter free download". Then you will find many organic results to choose from.
* Choose one of the files and download it.
* You can download the software for free, but most of them are trials and you need serials to activate them.
* It works for me, but you should only try the demo before using it.
* Below you'll find an image of the software and how to use it. You just need to input the file and choose the output format as ".asf".
