Hi! Is there Coreldraw gif animation inbuilt feature? I do programming in PHP and would like to make some simple animations for my website without using Adobe flash professional which I think is a bit heavy. Does coreldraw have that feature and if yes, is it any lighter than flash professional as I presume? How about complexity and ability to advance features as one gets to carry out more complex tasks? I need to make a decision to quick start the animation process. Thanks in advance.
Is there Coreldraw gif animation feature for web projects?
Animated GIF creator is powerful and easy to handle application, It allows you to edit create animated GIF images, It carry wizard like UI and also convert jpeg and .bmp graphics to .gifs automatically, Now i am sending you a link from where you can download this software, This software is comes for free, Follow the link below
http://www.sharewareconnection.com/animated-gif-creator.htm
Thanks
Hi there Kenneth Nickersonee,
Even though CorelDraw is a really powerful software, it is not designed to create animations but vector graphics. Therefore you can easily create each frame of your animation via CorelDraw, but to merge those frames into one animation you will need to use some other software. You can try with Photoshop or AnimationShop that is part of Corel suite or some simpler 3rd party applications or online tools such as
http://picasion.com/.
Best regards,
Drake Vivian
