Is there a .dat to PDF files converter for Mac Air?
My friend sent me a Peach text list manager file (.DAT file) and I want to convert it into a PDF. Is there a .DAT to PDF files converter for Mac Air?
.DAT files extension or data can be graphics, text or other data. If you wish to convert DAT files to a PDF you will have use particular program software. ABC Amber Clarion Converter is special software. It is a highly developed device which allows you to convert DAT files to any format like PDF file format simply and fast.
Best regards,
Heather marie
I agree with the previous post. DAT files are not always in binary format. Sometimes it contains texts or the contents are in text format that’s why using a converter may not be useful though the majority of the DAT files I’ve seen are in binary format. If the DAT file is only a single text file, here’s how you can manually convert it to PDF format.
Download and install Foxit Reader. When installing, make sure you check the option to integrate with Microsoft Office Word and other Microsoft Office applications like Office Excel. This installs a plug-in for Microsoft Office Word and other Office applications. Once it is installed, start Microsoft Office Word, open the DAT file, and then save it.
Next, select Foxit Reader PDF tab then click Create PDF located underneath the Office button.
On the “Foxit Reader Add-in” dialog, type a different name for the file if you wish to rename it and then click Save. And that’s it. Your DAT file is now converted into PDF format.
