Is there a dat viewer online Mac?
I'm very new to MAC and I would like to ask if there is a software online that can view .dat file? Please help me find a DAT viewer online mac. Where can I download it?
I can give you few links. But also you can view these files on your computer. Why don’t you try it?
I will tell you how to do this. This is very simple.
First copy the DAT file which you want to view. Paste it somewhere on your desktop.
Then rename the extension. You can change it to any extension except .dat, .jpg and .txt
Open the renamed file using an application. You can use any application for this.
That’s all.
If you want to view DAT file online. Go to following links.
Notifications
