Is there Dial Control in MS 2007 ?
Hi All,
I am a regular user of Ms Access. It had a very valuable feature of auto dialer in 2003 version. But I couldn’t find dialer control ms access 2007. Is there any such feature? How to add it in 2007?
Hi All,
Good day Bandler Faith,
Auto Dialer still exists in Ms Access 2007. To use it, create a form in Access. Go to the Design view and then add a command button. Use the Wizard On in the Miscellaneous category, go to the left side and you can see the Auto Dialer feature.
Hope this helps you,
Korber Owen
Hello there Bandler Faith,
First of all i would like to inform you, Mircosoft office never remove their old features while they are making new software or updating the previous one.So,basically there is still Auto Dialer feature is in MS access 2007.To use it,you have to go through some steps.
1. Create a form in Access.
2. Go into Design view.
3. Add a command button with the Wizard on in the Miscellaneous category.
4. You will find Auto Dialer feature on the left.
Hope this works for you.
Notifications
