There is dvd studio pro sync problem.
There is DVD studio pro sync problem.
When I am going to play back some piece of files it has an error occurred saying that I have a compatibility problem.
Why is this happening, please give a helping hand.
Answered By 0 points N/A #149005
Hey Ammelia,
The compatibility error occurs when the export settings are not right for the batch conversion and the export from FCP is not right. Do the following and it will solve your problem.
1. Go to the browser or timeline and select the sequence then make sure the in and out points are set.
2. Go to File > Export > QT (Not with Conversion). Make sure it's Self Contained, Current Settings set to USE, keep all the frames as it is.
3. Then in the Batch window drop the QT export into the Compressor.
