Is there an Edraw puzzle template where I can put an image?
I have been using EDraw Max for my flow diagrams.  I recently learned that I can also make puzzles out of it.  Is there an Edraw puzzle template where I can put a selected JPEG image as the image of the puzzle?  I'm on Windows 7.  Thanks in advance.
Answered By 0 points N/A #139564
Yes, there is some ready to use template that you can use in EDraw Max. But what I know is that it is only in Market Charting, which means JPEG is not supported. Here is one of the examples of the puzzle Marketing Chart.
And here is an example of Topic Chart:
If you want to make a puzzle of out your photos (JPEG) for free then try making it here. Follow the link below:
http://www.allstarpuzzles.com/misc/mk/picture.html
