There is an error about skype codec conflict. When I am going to make a call to the other side there is an error meaning I can’t call with skype because there is a skype codec conflict problem. How will I solve this kind of error and can you give me some guidelines or instructions to follow for me to be able to fix this issue? I really need your help. Thanks
There is an error about Skype codec conflict.
Hello Shannon,
You will need to do the following to resolve the error that you are getting when using Skype:
Either perform an update of the Skype application you are using on your computer,
Or you can go ahead and uninstall it completely from your computer, and then download the latest version that has the codecs that are missing and then install it.
Nicke
Hello Shannon Larry,
The codec conflict problem usually occurs if the required codec is not installed or missing from the computer. So I would suggest you to update the version of Skype. You can do it easily by turning on the automatic update option. For that, you need to sign in at first then from the menu bar select Tools and after that from Option you will find Automatic updates under the Advanced tab. Now turn on the automatic update option. Hope this could help you to fix your problem.
Thank you.
