There is an error while opening pak files linux.
Hi to everyone,
There is an error while opening pak files linux. What should I do when I encounter an error saying unable to open file? I cannot seem to find the right solution for my problem. Give me some suggestion on the application that will allow the user to open a pak file in a linux operating system.
Thank you.
Answered By 0 points N/A #185461
I have find a solution for you. You may helped by it.
PAK is one of the formats that usually packs the content of games to make protected data. There are   different kinds of PAK files . You  can open the PAK file simply by using ZIP-compatible unpacker .
If it not work you can also use ‘’The freeware Dragon Unpacker ‘’ , by it you can also extract archives of several other fronts.
Or you can use Pangya unpacker.
Thanks
Carrie Westmoreland
