Is there an extract mp4 files online tool?
Hello people.  I have compressed mp4 files in rar format.  I don't want to install WinRAR.  Is there an extract mp4 files online tool that I could use?  I'm on Windows Vista and Mozilla Firefox if that matters.  Any help would be much appreciated.  Thanks in advance.
Best Answer by Holloway Hively
Answered By 0 points N/A #139666
There is an extract MP4 file online tool that you can use. Using the AoA Audio Extractor you can convert the MP4 file that is in Rar format.
This is a free tool that can extract audio files and the music in the background of a video.
You can get more information from this site.
Answered By 5 points N/A #139667
Hi Dorethadhoward,
There are several online tools that can convert mp4 to rar or other audio format.
  • Online Convert – This one stop online site helps users convert several file formats to the likely format they want. It doesn't' only convert audio files but the other multimedia file format.
  • Convert Files – You only need to select the data source of the file you want to convert and configure the output then you will have the necessary audio file you wanted.
  • Online Audio Converter – from its name itself, you can definitely extract audio files from mp4 with the help of this online tool.
Also, you can try these stand-alone application in case you're not connected to the internet.
  • MP4 UI file tool – This easy to download utility software helps user modify and configure mp4 files.
  • AoA Audio Extractor Platinum – This free downloadable software helps user to convert mp4 files into corresponding audio files.
  • Mp4 Converter – This easy to use software is reliable and efficient in extracting audio files from mp4 to another audio format.
Hope this helps.
