Hi to everyone,
Is there a flash driver cleaner? We have to be more aware on how to secure our computers from harmful viruses. This can be acquired or obtained by transferring data from one computer to another using flash drives, we probably need a usb cleaner for this matter. Give me the safest and best recommendation.
Your suggestion is very much welcome.
Hi Amanda,
You can eliminate viruses and malwares by simply scanning it with your computers antivirus. The best way is to scan the flashdrive first before attempting to open anything that is stored in it. I think its the most practical way to secure your usb flashdrive. Making it a habit will prevent your files from viral infestation.
Hope these helps.
There are so many freeware apps on the web, which can use to clean your USB flash drive. USB Drive Fresher is one of the best USB cleaning software. USB Flash Fresher will automatically check and clean your USB Flash driver when it connects to the PC.
You can download this by clicking the following link.
https://usbdrivefresher.en.softonic.com/?
Regards
