eastwood
Posted on - 01/04/2012
In using an HP monitoring software for IT infrastructure, is there a function to check and record internet endpoints? I tried looking for this functionality but I could not find it. If there is none, perhaps there is a particular application that supports this function?
Is there a function to check and record internet endpoints?
There is no any function or application by which you can check and record your internet functions according to my research and knowledge. You can do endpoint security through some procedure but there is no application for checking and record internet endpoints in my knowledge.
Hello Eastwood,
There must be such a function that will enable you monitor end points in the HP monitoring software. Is it a trial version or a full version? If it is a full version then certainly it has that functionality. But if it is a trial version it may be having limited functionalities, recording internet end points being one of them.
Nicke
