Hello fellows,
Is there a Google file burner? I just want to ask you guys if this application really exists a Google file burner. However, I do have some researches to make about the said application and I need your help, discuss it with me guys. Your suggestions and opinions will be much appreciated.
If you are asking about online Google file burner then it’s not available but you can burn your data by other means like ISO Burner, burn my files, CDBurnnerXP etc. These software are good in contrast of online burning software. You can download these from the links given below.
ISO Burner
Burn my files
CDBurnnerXP
Thank you and hoping this is the answer of your question.
Google does not have a file burner but has a product called FeedBurner, which is a web feed management service. But if you are looking for a file burner, Windows 7 already has it as a Windows service. You may select all the files you need to burn, right click on it, then sent it to your optical drive, but just make sure your drive and disk supports file burning.
