Is there a hand held scanner
Hello , I need a device that I can take with me into a public library and scan articles. Is there a such thing as a hand held scanner.
Dear,
There are many handheld scanner available in market. Given below some top handheld scanner :
1. ModelMarker MMDx: The ModelMarker MMDx is the top-level handheld laser scanner ideally suited for portable 3D inspection and reverse engineering applications.
2. ModelMarker MMCx: The ModelMarker MMCx is the entry-level handheld laser scanner ideally suited for portable 3D inspection and reverse engineering applications.
3. K-Scan MMDxwalkaround scanning: It is a handheld walk-around laser scanner for portable meteorology applications in a large work volume.
4. LC60Dx dual-purpose laser scanner: It is easily interchangeable between CMMs and handheld localizers.
Thank you.
Since you are looking for a handheld scanner or a portable scanner, try Symbol DS6700 1D/2D Imager Scanner. This handheld scanning device is a combination of a barcode scanner, document scanner, and digital camera all rolled into one. The device uses text enhancement technology to be able to handle even the finest-grain text. With its wide working range and Omni-directional scanning, beginners can start scanning with least training.
Another one is the VuPoint Magic Wand Portable Scanner Black. This portable scanner offers up to 600 x 600 dpi high-resolution scanning for capturing text and images with finest clarity and detail. It supports microSD and microSDHC memory cards for transferring documents easily. It can scan up to 8.3 x 50 inches maximum size at 600 x 600 dpi to accommodate different types of documents.
It uses a single pass scan method and supports USB 2.0 for easy installation. It uses two AA batteries.
