Is there handhelds USB microscope?
Is there handheld microscope that ideal for work or study?
If there is, what is specification of it and how much it cost?
Hi Nimrod,
Yes, there is a USB Digital Microscope that could be use easily. It could be use perfectly for those who are studying or work since it is applicable for science applications, engineering work and study, dermatology exam, assembly and quality and control, for hobbies and a lot more, or you could use it for entertainment or simply as a reading aid.Â
The feature of the USB Microscope are: 8 LEDs White Light; Focus Wheel; Snapshots button; LED dimmer switch (2level); Image Sensor – 1.3 Mega Pixels; Video Capture Resolution – 1280×1024, 640×480, 320×240, 160×120; color: 24bit RGB; Lens: Dual Axis 27x & 100x microscope lens; Focus Range: Manual focus from 10mm to 65mm; Flicker Frequency: 50 Hz/60 Hz; Frame Rate: Max 30f/s under 600Lus Brightness; Magnification RAtion: 10x to 200x; Shutter Speed: 1 sec. to 1/1000 sec.; Video Format: AVI format; White Balance: Auto and a lot more. The package contents are USB Digital Microscope, Driver CD and a User's Manual.
It cost US $45.00
Hello Nimrod Abbot, your concern in the question if there is a hand held microscope for work or study, based on the research done, yes these are portable handheld microscope use to examine substance that are too tiny for the naked eyes to see.
These handheld microscopes are mainly used for educational purposes in school laboratories especially to introduce children to sciences. Though they may be employ in industries as well like the jewellry to examine sample for ranking and quality determination.
These hand held microscope, can as well be used for study in the field work, or viewing objects that may require enlarging though this at times may require a number of lenses. These microscopes at times lack condensing lenses which is very useful in making stronger light for purposes of clarity.
At Amazon a portable handheld digital microscope is costing between $10- $25 with the following specification:
Hope have answered your question
Good day!
