There Is A Problem With The Keyboard Some Keys Have Stopped Typing. Can It Be Repaired?
Some buttons on my keyboard won’t work, while the rest of them work fine. How can anyone use it? Can it be repaired?
No, you cannot repair a keyboard in most of the cases, while you can use some options if it is urgent, but it is advised to get a new one as soon as possible.
1. If you have some urgency, then you can use the On-Screen Keyboard option of the windows.
2. You can search for it in the start menu or open the control panel and look for it in the accessibility option.
3. While replacing a keyboard is easy on a desktop computer, it can be troublesome in a laptop.
4. If you are working with a laptop, then you should seek for a service center.
