There is an issues with the following XML
I have problem related to XML Errors which is I am trying to install Dragon Age, but after I put the disc and clicked on autoruns to begin the setup, I get several errors saying "There is an issue with the following XML:"
Error:
There is an issues with the following XML:
<xmlbutton name=”mute”action=”system”value=”mute”>
<size width=”23”height=”27”/>
<position x=”654” y=”7”/>
<bitmap normal= “.dataautorunmute_up.bmp”
Duplicat=”true” over=”.dataautorunmute_hi.bmp”
Normalmute= “.dataautorun|muted_up.bmp” duplicatemute=”true”
Overmute=”.dataautorunmuted_hi.bmp”/>
</xmlbutton>
This happens several times, and I cannot install. I am running windows vista operating system.
Note: Every time I try to install it takes two seconds
I couldn’t solve this issue, If anyone have any idea about this error please tell me.
I want to solve it quickly, waiting for any solution
Please help
Thanks Guys
