Edwaard Lee
30 points
Posted on - 05/14/2013
Hi there. I'm curious why the network light on my Linksys router keeps on blinking even though I'm not doing anything. Is there a Java program to capture packets so that I would know what my computer is sending and receiving? I'm on a Windows XP 64 bit system. Thanks.
Is there a Java program to capture packets?
Hi Edward. You'll need a little help if you want to capture network packets in your Java program, because no parts of the core Java API will give access to low-level network data. You can also use Wireshark to inspect packets on your network. You can use Wireshark in a number of your posts to show aspects of network performance and to illustrate areas of TCP or IP such as three way TCP handshake.
