Hi everyone,
Is there a jquery fire effect? I would like to ask you about the jquery scripting if it is capable of handling fire, water, rock effects and combined in my adobe flash animated creation. Tell me more about it, about merging and extracting files together with jquery.
Is there a jQuery fire effect?
Hello Anthony,
Yes! There is a jquery script that can do that. Actually it's a jquery plug-in called Jquery Burn. This is available for download so I will give you the link.
Heres The link for you to download: Jquery Burn Download LINK.
For more information on how to use jquery burn effect. Visit the link HERE.
This should solve your problem now.
The best plugin necessary for such effects is jQuery Burn.
In order to better reply to your query and for you to understand what this plugin is about, I will delve a bit on its functionalities.
Not only jQuery Burn optimizes co-existing animations together but it also gives you the option of using the fiery effects based on graphical and mathematical calculations, letting you choose the amplitudes and frequencies that you wish for the effects.
Another plugin you could use is Jquery fire. It's not as complex as Burn, but it still retains a couple of good functionalities applicable to your flash adobe animation.
