Is there a Laptop battery life tester?
My last laptop's battery was damaged due to exhaustion. Now, I don't want it to happen again to my new laptop. Is there a Laptop battery life tester that can measure its capability? Thank you.
Hi Dorothy Gallardo,
There is some freeware for you to test your laptop battery life.
–         Laptop Battery Tester: this program scans your battery voltage, then export the result to a picture or to an excel file. You can load old result (picture or excel) to compare with new result. You can download here: http://download.cnet.com/Laptop-Battery-Tester/3000-2094_4-10468524.html
–         Battery Eater Pro 2.70: this program measures the minimum of operation time that your laptop can work on battery. Especially, it support Multilanguage interface. You can download here: https://www.download3k.com/Antivirus-Spyware-Cleaners/Antivirus/Download-Battery-Eater-Pro.html
Hope this helps
