Is there a linux user management tool?
Is there a Linux user management tool? That can manage all the users of a specific computer?
I am just wondering if there are some application that contains this kind of feature.
Thank you.
Thank you.
Hello Trent,
GOOD DAY!
It would be better for execute directly users by using direct management through commanding in user manager. Here i suggests you more effective suggestion for get rid from the problem of managing hundreds of user.
Most efficient way for managing user of Linux is through commanding. For adds new user “useradd”, to delete persisting user “userde”, to modify “usermod” for add group add/mod/de also used with group. You also can use Tool watch for software based management. Use zivios for best management through Linux. For secure and effective direct user management command list you can get from here
Hi Trent Davis,
There is an inbuilt user management tool in Linux. So you can manage all users and groups in your computer using that tool. You can manage users using command line tool or using GUI tool. The easiest way is manage users using GUI tool. Click on System Menu click Administration sub menu select Users and Groups. It shows a simple user interface to create and manage users.
See this link to how to manage users suing command line. https://www.centos.org/docs/5/html/Deployment_Guide-en-US/s1-users-tools.html
Hope this is helpful.
Red Hat Enterprise Linux is a Linux user management tool that can manage all the users of a specific computer. It is more consistent, more open and more inclusive. Obtain more of the whole thing you imagine from an enterprise category release basis operating system with elasticity, competence and direct. It is your key across a wide variety of hardware to manageable, scalable and deployable clouds for hypervisors and architectures. You could administer numerous servers as simply as one.
Best regards,
Heather marie
