cmendoza
Posted on - 03/15/2012
My Google Chrome icon Suddenly changed to be Locked Google Chrome icon. I have reinstalled the program, but the lock still appeared.
Here is the picture:
And there is also red line on its frame. Like this:
Anybody know what's wrong with my Google chrome?
There is a Lock at My Google Chrome Icon
Hi
The problem you are facing is that your Google chrome has been showing lock and you don’t know how this has happened. To remove this problem the only option I have and you have and everyone have is that replace the Google chrome. First uninstall this chrome and then again install the Google chrome to resolve this problem.
Basically this is not problem you have locked your Google chrome somehow in the settings and now you are not able to do this. So for to set it up you have to re-install the Google chrome and then check it out this will solve.
Hope this solution will solve your problem.
