Is there a logo quiz software for nokia x2 series?
I need a mobile logo for Nokia x2 series.
Is this software available and how can i get it to be able to create a logo.Will logo quiz software produce compatible logo for Nokia x2 series?
After searching there are many sites for logo quiz software for Nokia x2 series.
All of them are not suitable for your Nokia x2. I simply suggest you for the best selection of logo quiz software.
If a welcome note is stored in phone startup logo will not be displayed.
You can use this program via infrared or cable connection without NCDS installed.
Some link is given below-
There are a number of websites where you can find and download logo quiz software for your Nokia X2.
The applications can be used to create or download wallpapers, animated Nokia logos and images. there are also available 3D logo quiz applications.
Some of the top websites where you can find the application include:
Samsung downloads net search results
Howard forums com showthread phpÂ
Thank you.
