Is there a Mac convert publisher files software?
I just discovered that you cannot view or extract parts from a Publisher file on Mac. Is there software for Mac convert Publisher files? Or would savie it to an HTML file be the easiest solution?
Hey there Joanna,
I know your problem can be frustrating, and there's no built in apps in Mac to help you with this. There are some online tools that can surely help you to extract Publisher files and viewing them if you convert it to another format like PDF.
One of them is Zamzar, they can convert your Publisher file to other format that your Mac can read.
You can also try pdf-convert.com and they can do the same job as Zamzar can do.
I hope this helps you.
Waall Mike
