Is there a Mac OS audio waveform display seekbar?
I'm trying to find a seekbar program or add-on for Mac OS audio waveform display. OS is Mountain Lion 10.7.4. I'm trying to add a waveform preview of a track that is loaded.
Thanks in advance.
Thanks in advance.
Hi John,
Yes there are some of Mac OS which can help you with this problem. Go on and download any one of them, install, use it and enjoy. Some of these programs are totally free and some are commercial.
1. Virtual DJ Home Version (Free).
2. Transition Player (Free).
3. MIXXX (Open source).
Here is the image of transition Player how it looks.
Jackson William.
Hey,
I got an answer for you. I wish my answer will help you!
An audio editor is better than a player what exactly accomplishes the total requirement. However, fission from rogue amoeba is appropriate device which furnishes waveform of the loaded audio file. It can be zoomed in and out of segments of the audio and pinpoint the same according to someone's choice.
Notifications
