Is there a madagascar 2 uninstaller?
Hello experts,
I got the game Madagascar 2 was given by a friend of mine.
But suddenly when I tried to access the game it always give me an error saying not responding and sometimes automatically crashes.
And I decided to uninstall it from my windows 7 starter operating system, kindly guide me along the process and explain some reason why is it happening.
Thank you.
Best Answer by Goram Ian
Answered By 0 points N/A #178579
Hello Bryan,
Have you tried uninstalling from the control panel?
If you haven't I will suggest that you access the control panel and then go under add/remove programs and then locate Madagascar 2 from the listed applications.
Click on remove to uninstall the application.
You might also want to remove it from the program files under C: on your computer.
Nicke
Answered By 60 points N/A #178581
Hi Mr. Bryan James,
As I have searched the internet and Google for some possible answers/ solution with your concern, I also discovered that there is a lot of Madagascar 2 Users also encounter this problem.
I have attached some reliable links that maybe helpful for your concern.
Fixya support Cannot Uninstall PC Game Called Madagascar 2
Yahoo Answers How to uninstall Madagascar 2 Pc game?
Answered By 0 points N/A #178583
Hello Bryan,
Download a software Perfect Uninstaller. It will uninstall your game completely and safely.
There is another way to get rid of your game.
1. Go to Run
2. Type regedit
3. In your registry editor open hotkey Local Machine and then software
4. Delete the folder of Madagascar 2
This will do the trick.
Thanks
