doriswneil
50 points
Posted on - 05/29/2013
Hi. I have a 32 GB Samsung Galaxy S2 that has the Exynos chipset, Dual-core 1.2 GHz Cortex-A9 CPU, Mali-400MP GPU and Android OS Ice Cream Sandwich. Is there an md5 jar generator from file that I have? I have a .jar file that I would like to have md5 verification if possible.
Hi Doriswneil,
I have here the app that you might wanted, it is called AFV or the Android File Verifier. It is an application tool for helping verify and validate files that are being transferred to your android mobile phone (original and clean). It can MD5 / SHA1 checksum / digest calculation that supports SHA-224,256,384,512 algorithms. It can also validate jar type files (.jar .apk. .zip)
