Is there a menu for cute smileys for Skype?
Is there a plug-in or menu for cute smileys for Skype? It's kind of annoying for me to type them every time.
Emotions menu anyone?
Hello there Joshua,
Unfortunately Skype only have their own emoticons and you cannot have any other plug in or app installed to have new smileys.
You may want to see the hidden emoticons they have from this site and you'll see that they are actually cute and funny.
Hope this helps you.
Waall Mike
Hello Joshua
The only way for you to use cute smileys in Skype is to know the code for them. Unfortunately at the time, no plug-in has been designed for these, but you can find the codes by accessing the links I have you.
Skype Emoticons which shows you every animated icon and the code for it and also Flag codes
Skype Hidden Emoticons which also show you the Flags and also some hidden emoticons usable in Skype
I hope you will find this information useful.
Randolph
Notifications
