Hello there,
I use ODBC clean up tool to clear out ODBC DSN entries from the Windows registry in a Windows Vista 64 bit system.
My other system is a Windows XP 64 bit and I can't find ODBC in administrative tools.
Can someone help?
Is there ODBC clean up tool in XP?
Speaking about Windows XP, I would advise you to use CCleaner:
This tool is free and it is the best free application for cleaning your computer.
It will clean all your junk files, registry files which are unneeded, also it will defragment RAM and many more things.
I think this far better solution than using ODBC.
I hope I helped you.
Regards.
Although CCleaner is the simplest solution, I would advise you to try Advanced System Care.
This tool will provide you with all the tools you need to maintain your computer in a clean and optimized condition.
It will delete unnecessary files from your computer, also it can clean your registry and many more things.
Try it out.
I hope I helped.
Regards.
