Harold Rudy
50 points
Posted on - 04/24/2013
Hi there!
I am documenting all details of meetings undertaken by our organization. This involves taking of pictures, videos and text notes. Whenever I am using my personal computer I find it very easy, though for travel it becomes a bit cumbersome moving around with the laptop. Is there OneNote Blackberry compatible application? Thanks a bunch.
Is there a onenote Blackberry activation option?
Hi Harold,
There are several apps that you may use for blackberry that do everything the MS OneNote does. One such app that I personally use is the MobileNoter SE. Check with customer service to ensure you have the correct build. You may also want to consider the IdeaMatrix. Choose an app that best works for you. Be advised, user experience generally differs from one person to another. Have a good one.
