Is there an openoffice hebrew 2011?
Hello experts,
Is there an open office Hebrew 2011? My friend which is using Hebrew language is staying in my house for how many weeks before he gets back to his place. How can I let him borrow my open office software if he cannot read the content? Is there a way to get some Hebrew language plug in for open office 2011?
Best Answer by Jock Abram
Answered By 5 points N/A #135423
Yes, there is an open office Hebrew 2011 software. You can download the software on the following site:
https://www.openoffice.org/download/other.html#aoo
It is already updated in Hebrew.
Answered By 0 points N/A #135424
James Mayer,
Greetings!
You are asking if there's an Open Office with Hebrew plug in on it. Is that right? Definitely yes, actually there are many forums on the internet that give some tips about that. Here's the link https://extensions.openoffice.org/project/numbertext
You can follow all the instructions in that link. And that's your guide on how to install that Hebrew plugin. If still doesn't work try this http://www.openoffice.org/he/  â€”—- or this open office forum http://forum.openoffice.org/en/forum/viewtopic.php?f=7&t=21972
Hope it helps you solve your problem.
Answered By 0 points N/A #135425
Hello James Mayer
Hope that my message finds you well.
Please follow the steps below to solve your issue:
Download the openoffice hebrew 2011 software from the below link
http://ptf.com/openoffice.org/openoffice.org+hebrew/
If you did not solve it by the upper solution here is Another guid for your problem you can follow this link:
Hope this solution will help you and let us know the results.
Kind regards,
